Engine Oil Level Critically Low
Hi all,
I have a peculiar problem with my Jag (X260) XF. Every now and then (at random times) I recieve an error message "Engine Oil Level Critically Low" on the dash. I checked it with one of the dealers in Bristol but they couldn't find any problems when they ran a diagnostic. The engineer suggested to change oil pressure switch to see if that could resolve the issue. So I went ahead and requested to change it but with no joy. I then took to another dealership and the engineer suggested it could be a piston cooling jet but not sure about it (We went into lockdown so I couldn't get that done). Nonetheless, I took the car for service (major 105,000 miles service) to the dealership and they ran eVHS service but the system did not find any faults. The car shows everything is running fine with no historic issues from the system.
I am wondering, does anyone here have had same experience and if yes then what did you do to fix/correct it?
The error pops up at random, there is no fix time or method of running that would trigger it. Can you also recommend where I can buy JLR diagnostic kit so that I can run it myself?
Many thanks in advance
Kind regards
Jay
Kind regards
Jay
So now you have had the 105k service down, the oil level should be correct, yes ? I suppose it's got the stupid electronic oil level system which is totally unnecessary. Nothing, absolutely NOTHING is better than a dip stick. Even when the Rover 90s and 105s had an oil level indicator, the dipstick was still provided
Carson City Smith (08-20-2023)
Any motor temperature rise when this happens? Does the warning go away on it's own? Do you need to cycle off/on for it to go away? What does the oil level check show when you get this warning? Does the motor use oil between changes? If the level check says it's OK, motor doesn't use oil, oil pressure switch has been replaced, warning comes and goes on it's own, no temperature rise, I would guess a spurious system response and I doubt a diagnostic tool will show anything.
I can't see how a oil pressure switch should affect the oil level reading. They require you to turn the engine off for 10 or 15 minutes before you get the oil level reading on your display panel, that should be to let the oil drain and settle and for any oil pressure to disappear.
The lack of a dipstick is quite annoying.
Get an independent mechanic to suck all your oil out, measure the amount and put it back in. That is the only way I can guess to confirm the visual interface on your dash board display.
Do report back with any developments.
P. Smith
P. Smith
It is unclear..
Although the Vehicle Fitment Guide Section only includes the 3.0L from the XE, there is null return on searching for Oil Temperature Sensor on the AJ126..
But here is the Pressure Sensor:
https://parts.jaguarhiltonhead.com/o...witch-aj813129
The Oil Level Sensor is:
https://parts.jaguarvirginiabeach.com/oem-parts/jaguar-level-sensor-aj812432
P. Smith
P. Smith
jaytheguru (02-02-2021)
According to JEPC, the X250 2.2 litre Diesel has an oil level sensor in the bottom of the sump but the X260 2.0 litre Diesel has a dipstick. Both were available in 2015 so which is it?
I believe it is X260 2.0ltr diesel, definitely not X250 as the log shows it as x260. Here is more info when I put my reg into one of car parts website,Make:
Jaguar
Model:
XF
Year:
2015
Type:
2.0 D
Engine:
1999ccm 163HP 120KW (Diesel)
Variant:
X260 [Saloon]
Transmission:
Automatic
Engine Number:
151104W0041204DT
Engine Code:
204DTD
kind regards
Jay
Jay,
My 2019 version of JEPC doesn't list an Oil Level Sensor for the 2015 X260 2.0 litre Diesel but British Parts UK sell one for it which must be right!
They show it's the same as the one on my XK and is bolted into the bottom of the sump. Yours is likely to have a bad harness connection or be a faulty sensor to cause the intermittent "Engine Oil Level Critically Low" message.
F1Virginia (02-03-2021)
Deleting the engine oil dipstick must be the stupidest design decision made by engine designers - and it's not just Jaguar either - Audi and Mercedes have done it also. It can't save much, if any, money and in fact the electronic indicator will likely be more expensive.
Without a dipstick and after an engine oil change you have to carefully measure the quantity of new oil into the engine and you can't check it until running the engine, turning it off and letting the electronic indicator confirm (you hope!) the level. What a faff - with a dipstick you just add the oil in increments, checking with the dipstick until it's full.
And when you get a low level oil warning when driving you've no independent way of checking the oil level without a dipstick, so are left in doubt about how much oil (if any) you need to add for what is a critical matter for the engine.
The lack of a dipstick would seriously put me off buying a car - luckily Jaguar have retained the dipstick on the Ingenium 4 cylinder engines. I don't know why they've deleted it on some of the larger engines - it smacks of wanting to demonstrate the manufacturer doesn't expect its customers to do anything "oily".
Jay,
do you think this can be changed by jacking up the car or should I call Jaguar showroom to do the job? Hopefully this sensor can fix the issue. If it’s fairly easy to remove I might try it myself.
kind regards
Jay
