EPR Procedure for mark2 XF 2017
There's a transmission park release handle under the engine cover. Use blade key to open door, pull hood release, lift engine cover and pull handle, attach power to jump start posts to release pbrake.
Basically they have moved the cable that was behind the gearshift to the engin bay under the cover sort of makes sense. You are expected to get power back in for the handbrake release, there is no cable for that.
As you say should have been in the manual. Printed the PDF and stuffed it in the handbook. Not all towing operatives will have a flat bed or know how to isolate the drive tran.
