Front License Plate Mount
My dealer installed a plastic frame with a contoured mount behind it. It is inoffensive, at least as a required front license plate can be.
From past research, I've seen various brackets that attach to a threaded tow hook mount. In the case of the XF, the angle and location would be far uglier than the stock mount IMHO.
I also recall seeing assemblies that attach beneath the front "bumper", and while searching for an example I ran across License Plate Central at License Plate Accessories Looks like most available solutions are shown on that site. I also ran across retractable plate mounts with wireless remotes, apparently for show cars. Surprising how many traps there are for this particular mouse.
I bit the bullet and had the dealer install the plate. The find for not having one far exceeds the cosmetic value of not, at least IMHO.
Bringing back this Thread, I just got my plates today, I went with a SlyBracket, fits perfect, my only concern is that pretty much completely covers up the vent on this side, are the front lower corner vents to get air to the rotors and does it look like enough air can still get through ? The kit comes with extra spacers so I could mount it in to the lower middle vent, I just really like the look of it on the side.
Sly Brackets / BozzMount
Say what? It's usually just a fix it ticket (no fine) in California if they even bother writing you up for it. I've been told by several police officers that the "no front plate" is overlooked because it gives them an ideal situation to pull someone over if they're just suspicious. For a while they were ticketing people for no front plate in my neck of the woods because red light cameras were being installed in a lot of locations. Then something happened ..... I think they were successfully challenged in court .... and the cameras came down.
