Gear selector stuck in Park
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
My gear selector will not allow me to select a gear, it's stuck in Park. Embarrassingly I have been recovered home on the back of a breakdown vehicle. This is the second time its got stuck, the morning after all was OK and no problem this is now the second time it has done this in three weeks . My local Jaguar dealership states it requires a diagnosis & software update £500, Another jaguar dealership 10 miles away suggested a gear selector motor module £500. can anybody help with this?? has anybody experienced this before
So, from what you say, the gear knob rises normally but when you try to move it to select a gear, it won't move, correct. Is the knob rising to its normal height ? As said here, if the input from the brake switch isn't getting through, the TCM won't allow any gear to be selected.
These gear selection mechanisms have been around since the first XF (X250) came out, and some troubles were experienced early on, but your 2015 should not really be suffering a problem. Fact is yours is the first time I have seen this reported fault, although to be fair, I don't often visit this particular forum. What miles on the car ?
Are you totally dependent on Jaguar main agents ? There are some independents around that will probably have seen this fault before. I know of one or two locally in Cheshire, but not in Oxfordshire. There is also Dave Marks in Nottingham; it might be prudent to give them a call.
My 2017 XF had that transmission issue like yours during delivery 6/22/16, although I also had a fault light. I started to occasionally experience a momentary "stuck in park" problem about three months ago, which I'll report at my next service vist. I scanned the service document text, perhaps it will help:
A GEARBOX FAULT LIGHT IS ON CAUSE: .
444001 VALVE BODY ASSEMBLY - RENEW 46 WJ2
7 JDE26444 OIL-TRANSMISSION
444000 STRG TIME-DIAGNOSIS-TRACE CODE Pl707-77//SECURE PARK ACTUATOR SOLENOID
46 WJ2
DIAGNOSIS-INSPECT FOR FAULT-Pl707-77-TRANSMISSION NEUTRAL INDICATOR CIRCUIT-INSPECT TRANMISSION SYSTEM-CONNECT SDD AND RETRIEVE DTCS-FOUND Pl707-77 LOGGED AND CURRENT-MANUALLY INSPECT PARK RELEASE SYSTEM FOUND NO FAULT-CONTACT TECH LINE AND CHECK CABLE ADJUSTMENT-PARTIALLY ENGAGE PARK RELEASE-NO CHANGE-DISCONNECT PARK RELEASE CABLE AT TRANSMISSION AND TEST-NO CHANGE-USING DATALOGGER MONITOR GEAR POSITION-DESIRED AND ACTUAL AS WELL AS SWITCH AND SOLENOID STATUS-FOUND STATUS PID DISPLAYING ERROR CODES-RECONTACT HELPLINE AND ADVISE-FOUND NO OUTPUT STATE CONTROLLABLE FUNCTIONS AS DESCRIBED BY TECHLINE-OBTAIN FRED AUTHORIZATION-UPON TRANSMISSION SUMP REMOVAL FOR REPAIR FOUND PARK ACTUATOR SOLENOID PARTIALLY DISCONNECTED-INTERMITTENT CONTACT-SEND PHOTO AND FINDINGS TO TECHLINE-INSTRUCTED TO REFIT AND SECURE CONNECTOR AND REINSTALL SUMP, REFILL TRANSMISSION AND TEST-TRANSMISSION FUNCTIONING PROPERLY-CONNECT SDD AND CLEAR CODES AND RESET ADAPTIONS-ROAD TEST AND RECHECK FLUID-OK
46 WJ2
Biff Baxter
19
02-28-2018 03:20 AM
Rogelio Serrano
12-04-2016 10:50 AM
