Help: Water Ingress into Boot
Hi all
I have a 2016 x260 Jaguar XF.
Over recent months I have started to find water ingress into the boot space, collecting underneath the battery. I removed the bung which has allowed water to drain out but it continues to collect on rainy days.
I have pulled back the liner surrounding the boot, and cannot see any obvious location for water to enter (I can see no water droplets on metal surfaces on the inside of the car’s shell).
All my Google searches return results for issues with the x250 model, and I’d really rather avoid removing the rear bumper and rear lights unless I know the issue is definitely in that location.
Has anyone has any similar experience or can point to other discussions elsewhere on the issue?
Any input would be appreciated.
(I’ve recently had intermittent issues with all speakers in the car doors which I figure could be related so it needs resolved sooner rather than later)
I would star and remove all the liners in the trunk( which sounds like you did) and then run a hose down the back glass, from the roof and check for leaks. Start by either climbing in the trunk and closing or if you have fold down rear seats crawl in there with a flashlight and try to find the leak that way. It can be tedious and time consuming but you should be able to locate the area of the leak.
I don't have fold back seats (such is life) so it'll be a cramped job!
police666
09-10-2013 03:26 PM
