Help with water pump hose number 3.0 AWD 2013 (US)
Hi All,
I think I ordered a wrong part - it looks closely similar but the "kink" on the side tube that goes to the water pump doesn't seem to fit?
below is side-by-side pic, broken tube one is the original one. new one that I ordered is LR012636 water pump hose
Hey memento84!
I like to use https://parts.jaguarpalmbeach.com/ whenever I feel stuck trying to find accurate parts. I have on our "Water Pump Kit" for replacement parts C2Z18658 C2Z26930 perhaps its one of these you're looking for? Hope this helps!
Not sure if your issue is resolved but I did the same thing. Ordered new water pump and the companion hose. When it arrived, the hose was the Y shaped hose and the one I took off my XFS was a single hose. I just said "F" it and cut the hard plastic line and used the 90deg elbow with the one-way valve in it and put it in my original hose with the clamp. Fixed. I have pics if it helps
