HID headlights upgraded to OEM LED headlights
I have upgraded my headlights to the factory fit LED lights they were a straight swap and all work fine only issue is the dash indicator light flashes fast guess it's because it thinks the bulbs are blown I can get round this with resistors but would like to get the error disabled in the CCF
Does anyone know how I could get this done none of my local dealers are interested in helping
Mr. Kerry,
I'm not sure which Headlights you have upgraded, if you mean you have changed-out the Low Beams, which are HID Bulbs with Ballast, I would wonder why? As tye are really good Lights......I would change them back if you are getting a CanBus problem...If you changed out the High Beams and you are getting this error, you have used the wrong LED kit and need to go back to the seller with your problem.....They have sold you the wrong Kit!
Billy Clyde in Houston
Ian, The HID Light man!!
Ian,
Since I don't know which Light Assembly you have installed, I would love to see a Photo of them. I'm not aware of an LED Head Light Spec from Jaguar, nothing other than the standard set-up...…Also, if it came from Jaguar, why did you have to put in Resistors? You would think that the Jaguar Engineers would have thought of that already!
Billy Clyde
Billy Clyde
Ian,
Since they changed the Website a couple months ago, all kinds of funny things have been happening....I'm on the X-100 Forum and now it says that I am on a Related Thread....It says that You Joined in Nov 2012 and that this is your 5th Post and that your are from Chester....Where the Hell is Chester?
The following 3 users liked this post by mleskovar:
Resistor Placement
(ANYONE) Advice or divine knowledge of how I could get this to function w/o re-wiring the whole vehicle with the 2012 Electrical Wire harness would be most appreciated!
2011 Jaguar XF-R (ECU Remap Custom Exhaust, Pulley Swap)
Hi Ian, I have also changed the assembly to full led and me too having the turn signal going fast, how and where u actually put in the resistors to fix the problem
any brighter?
Hi both Ian Kerry and SKS, or anyone else. are the headlights now less yellow with the LED upgrade? i'm not so concerned about the light output, from a cosmetic point of view has that ghastly yellow look gone? at the moment my headlights look like they are halogen and not BiXENON.
thanks
did you manage to solve the flashing indicator problem with a resistor or programmed it in?
The following 2 users liked this post by Googsy:
dangoesfast (06-24-2024),
Panthro (12-16-2023)
Is it possible to "Switch" the DRL and turn signal function via wiring swap? Or through coding? I have not investigated the harness yet, but was hoping maybe the OP or anyone who has done this swap might be able to answer.
I like the thought of amber DRL's on the car (like what is used for signaling) vs the white OEM default. I wouldn't mind trading, or omitting the white setting all together. Amber strip as DRL, Flashing Amber during turns/hazard function
