How to remove the rubber shroud over the cylinder heads to change plugs?
I have a USA 2011 XF Premium 5.0L which has just on 40k miles.
I've started to get 300 errors with 2 or more cylinders, so I'm trying a few things to rectify it:
Is there a trick to getting it off? It seems to be caught between the last coil and the side of the engine bay, Could the motor have dropped slightly (deteriorated engine mounts perhaps?), or what?
What seemed like just a challenge (due to tight engine bay), seems almost impossible right now.
Any other advice on what to check for 300 errors (300, 301, 302, 306)?
I have purchased to NGK iridium plugs and checked the gaps. Do you recommend putting copper paste on the plug threads prior to installing?
Thanks in advance for any advice. guru's.
- Added fuel injector cleaner to the gas/petrol to give the injectors a clean to see if that helps.
- Trying to replace the spark plugs.
- Maybe will check the fuel filter if all else fails.
JX350
11-06-2018 09:53 AM
Collector1
11-28-2015 05:12 AM
