There is usually no problem with aftermarket wheels, just check the diameter of the jaguar caps where they insert into the wheels. The centre holes are normally a standard size although I can't remember the exact diameter.
I've found that they don't fit on my aftermarket wheels. Depending on the hub bore and wheel style there are many many different sizes and types of center cap
If you want to preserve the jag look on the center caps, buy the round jag emblem (eg on eBay) and stick them onto the center caps that come with your wheels. If you want perfection there are people who will make them to order at your size preference
