Jaguar XF 2012 Shifter won’t rise stuck in park?
Ok, as stated I have a Jaguar XF 2012. Base model. About 115x miles. About a week ago I come out to my vehicle it started but gear shifter won’t rise. Read somewhere it’s possible to still shift even if not raised. It won’t. The stop start light is not illuminating nor the gear (park). I hadn’t gotten any warning prior but now says “gearbox fault” it had been stating “service required” but it had been on only about a week and I kept driving at a minimum. I’ve read that there’s a fluid that could be low in the gearbox, break switch, or the most unfortunate the transmission. I’ve had this car only 6 months. Independent dealer. PLEASE HELP. Looking to do most work if possible myself or a knowledgeable independent mechanic in Ohio/Michigan area. Thanks In Advance ❤️
Hi-Velo-Sid-E
05-28-2016 01:25 AM
jaguars-type
29
11-12-2014 09:20 PM
giandanielxk8
01-06-2013 04:06 PM
texmanmoore
08-05-2010 01:01 PM
mel
04-01-2010 10:56 AM
