Jaguar XF missing emergency release lever
Hi guys,
I own a Jaguar XF X260 2.0D from 2017. I bought the car a while back. Unfortunately, due to an accident I have to tow it. However, the 'pull lever' in the engine bay (next to the engine cover) doesn't have the cable as I see in other videos. It seems broken or w/e.
Any idea what I can do now? Engine can't be started due to a rod knock. See picture below, it's not a video.
If the release lever is not connected to the cable, then someone forced the lever out and broke it. Search the cable, it is somewhere in there. Check if the cable has the head connector and you can still re-attach it. If not you have to buy a new one.
***Follow the path line of the cable for removal & installation if you need a new one installed:
P/N is T2H7726 (122 UKP from Jaguar)
Enjoy the forums.
blackscell (08-10-2022)
Welcome to the forums blackscell,
Enjoy the forums.
Enjoy the forums.
I am also looking for the ACC frame bracket, can't seem to find the partnr anywhere. Could you see that info by any chance?
tdellaringa
05-15-2021 07:13 AM
Geoff_C
03-12-2020 10:38 AM
