On my 2016 Jaguar XF 35t R-Sport Im having to continuously go into display settings to select Map View on Speedometer every time I start the vehicle. Is this the way it’s set up on this model year. I’ve noticed on the E-Pace and F-Pace this feature stays on once selected unless turned off.
What are you asking, slightly confused? I have the same exact yr/trim. I have to select map from the center screen and tap the warning before I'm able to view maps.
My apologies if I wasn’t clear. On this model/trim you have the option to view maps/Navi on the speedometer which covers the whole digital odometer vs having the map/Navi on the infotainment center. However when this option is selected and I go about my day. It seems that every time I cut my car off , I have to go and select this option over and over again. I notice in the Paces this option stays on once selected. So my question was is this normal for the Jaguar XF or does it suppose to stay on once selected?
Hello, I don't have the In-Touch Pro on my XF, but there is a video for a 2017 F-Pace and the guy is demonstrating about his Infotainment System. On the last part of the video he is talking about "Customization" wherein you can create your own "Homescreen." Maybe that's the one you need. It starts at timer 06:35 on the Customization.
Same as mine have to every time set it to maps
on another note I see somewhere someone had the reverse camera on the display as well don’t know how that was done
