Meridian 380W and 825 Watt Specs
I was websurfing and I ran into actual speaker and amplification specs for the Meridian 380W and 825W Sound Systems. These should be mostly good for XE owners as well as XF as most enclosures are the same except for the subwoofer ( located in rear wheel well inXE instead of under spare tire on XF.) Thought this info would be useful for those that discuss upgrading.
Jaguar XF Meridian Audio Specs
25mm Tweeter
Nominal Impedance: 4Ω
Power Handling RMS: 25W
Power Handling Max: 50W
Sensitivity (1W/1m): 88 dB ± 2dB
Resonance Frequency: 1.4 kHz
Operating Freq Bandwidth: 3 kHz – 20 kHz
THD @ 10W: <1%
100mm Midrange
Nominal Impedance: 2Ω
Power Handling RMS: 70W
Power Handling Max: 100W
Sensitivity (1W/1m): 87 dB ± 2dB
Resonance Frequency: 115 Hz
Operating Freq Bandwidth: 200 Hz – 5 kHz
THD @ 10W: <2%
Linear Excursion: ± 2mm
165mm Bass
Sensitivity (1W/1m): 89 dB ± 2dB
Resonance Frequency: 60 Hz
Operating Freq Bandwidth: 60 Hz – 3 kHz
THD @ 10W: <2%
Linear Excursion: ± 3mm
250mm Subwoofer
Nominal Impedance: 2 x 2Ω
Power Handling RMS: 2 x 70W
Power Handling Max: 2 x 100W
Resonance Frequency: 50 Hz
Operating Freq Bandwidth: 30 Hz – 100 Hz
THD @ 10W: <2%
Linear Excursion: ± 10mm
Enclosure Volume: 32 litres
Amplification
Type: Class D with feedback.
Channels: 12 or 15.
Power Rating (0.2% THD): 380W or 825W
25mm Tweeter
THD @ 10W: <1%
100mm Midrange
THD @ 10W: <2%
165mm Bass
THD @ 10W: <2%
250mm Subwoofer
THD @ 10W: <2%
Amplification
Channels: 12 or 15.
Aioros13 (03-05-2020)
Thanks for the corrections, Cambo. I was just happy to see some of the power handling specs and stuff. You're right about the subwoofer being a completely different design. Should I move the post to the X250 subforum?
What surprised me about the specs for the drivers was that I expected them to have a greater sensitivity than what is listed.
The 825W Surround System has a front center speaker which is coaxial (00mm midrange/25mm tweeter combination). Sorry but no part number shown. Evidently the 380W system doesnt have a front center speaker per Meridian info. Pls refer to link below for detail
https://www.meridian-audio.com/media...t-a-glance.pdf
billqs (05-21-2019)
Hey N24SHS,
The listing should specify, or at least say how many speakers. If it doesn't, then check out the dealer brochure.
I've downloaded a few of them while I was shopping from here:
Auto-Brochures.com|Jaguar Car PDF Sales Brochure/Catalog/Flyer/Info E-Pace F-Pace I-Pace E-Type F-Type S-Type X-Type XE XF XJ XJS XK
Then compare the info from the brochure to what the vehicle actually has. For mine it was a difference between 13, or 17 speakers that made it easy to figure out. Good luck, and happy shopping!
Hey N24SHS,
buickfunnycar.com
08-11-2015 08:51 PM
