Neutral with a dead battery
The owners manual gives no helpful information on how to put the transmission into neutral for moving. Is it the same remove center console panel and pull the red strap (still hard to believe they actually did that)? There's few enough Jaguars around my neck of the woods to worry about this.
All tow truck drivers know that if the car has a dead transmission they cannot tow it on either the front or rear wheels depending on car. BCAA here and AA or AAA in UK would be same. They know the safe way to move your car if it cannot be boosted or driven. it is generally not recommended to tow any auto car in neutral for more than a short distance and below 50MPH here. I would specific the flatbed and see if it is available. Otherwise they tow the car Rear up or front up depending on the fwd or rwd.
I don't have the same confidence that all the tow operators in the South West United States have the expected expertise. I want to be able to instruct them if they don't know. There's many stretches of 100 miles in the deserts that have limited towing capabilities and you get what is available. I have 5 years of free towing but that doesn't mean I want my car damaged in the process just because it's covered. Yes I'm being over concerned but experience tells me it's better to be safe than sorry. Incidentally, I've never been towed in 55 years of driving except once when the car was totaled and damage from towing meant nothing.
I share your concern. If the tow truck picks up the Jag by the rear(ie re txn) then the nose is on the ground. It makes me shudder. We have the Jaguar Emergency number which I would use and they would hopefully send a rig which can flatbed the car. Hope I don't have to find out or you either. And we do go Stateside too.
AL
Many of these cars are AWD so you won't want to tow on either set of wheels
And even with a flatbed they will need to drag the car on its wheels up the ramp onto the flatbed. So you will absolutely want to disable the transmission.
There must be a way to do it - surprising that it's not in the manual. Is there a small panel in the central drive tunnel with the red tag in it like on the older XF model?
I asked in the thread starter but no responses.
To put a 2016 and up Jaguar XF in Neutral
From the AAA Road Service manual.
Operating the Shift Interlock Override: The shift interlock override is located in the engine compartment on the driver’s side of the intake manifold. To access, carefully remove the black plastic cover on the intake manifold by lifting upward.
Lift the black lever on the shift interlock override to the vertical position (1).
Engage the securing latch to hold the handle in position (2).
The transmission will remain in Neutral until the shift interlock override is released.
Here is a link to the manual there are illustrations
https://aaacampus.aaa.biz/wp-content...F%20QRG%20.pdf
I had a similar problem a few years ago when the transmission on my BMW died....3 tow trucks could NOT get it in neutral. it was AWD...so towing was not an option, had to be flatbedded.
some trucks come with "skates"....a plastic piece that they can slide under the wheel to slide the car on the flatbed. the wheels dont turn
