P0016 Cam shaft position bank one
I have an 09 Jaguar XF luxury 4.2 thats been starting rough. The other morning about 5 miles into my drive I hit 70mph, light changed so had to break quickly. When the light turn green I pressed the gas and the car wouldn’t go over a few mph. Put the car in neutral and the rpm’s pressed the gas rpm’s went over 2000. Put it back in drive and it would go over 1000 rpm’s. Got an engine system fault on the dash. Code P0016 camshaft position sensor bank 1. My question is where is this sensor located and will replacing this take care of the code and the Engine system fault?
YumiDad01
12-03-2021 01:39 PM
