Sguerguer
Hi everyone I have a jaguar xf 2018 the car had a small accident to the front left side , since then the car isn't starting? Took the car to jaguar dealer they charger me 2000 pound and the car still not starting im depressed facing a huge bill and my didn't start ? Any one faced the issues after an accident? And had solved please help.
Where are you located, please, (country) ? Sometimes if an accident occurs the fuel cut-off inertia switch can be triggered. This is normally on the driver side in front of the door behind a small panel. However, I would have thought the dealer would have checked this. To reset is very simple; there is a button on the top of the switch. You press this down to reset the switch and the car should then restart. What is the exact symptom of not starting ? Does the engine crank over when you turn the ignition switch, but doesn't start, or is it totally dead ? Do the lights etc work ?
Jaguar Forums Editor
Jaguar Press release
05-29-2024 06:18 PM
