Smart key low battery warning.....
I keep getting this reading with both of my smart keys. The batteries were replaced a year ago, and usually they last longer.
Anyway - I changed them and am still getting the reading "SMART KEY BATTERY LOW".
This occurs in my driveway by my house or anywhere else. There have been no changes to any other wireless devices in my car or my cell phone.
It's disconcerting - and I'm looking for the remedy, believing its a faulty reading.
If you have any ideas, I'd love to hear them. Car runs great otherwise.
Thank you!
__________________
Thank you!
__________________
Received 2,643 Likes
Dallas Rockford (10-18-2017)
Try the car with one key - with the other one way out of range. Then swap and try again. That should help you identify which fob it believes to have a problem.
Once you work that out, couple of suggestions. Try replacing the fob battery again in case it’s a bad one. And also check that a button isn’t stuck in or getting pushed when you store it. Someone had that problem a year ago - button was stuck on and running down the key fob battery in a day or so
NBCat (10-18-2017)
Make sure the battery gets to reach a quiescent state before taking the measurement. Opening doors or anything that uses electricity will cause the battery to show low voltage until rested. The headlight fans draw some current and remain on for about 15 minutes after closing a door.
