Speedo Calibration
sn1peril, yes, there is an adjustment in the computer that will allow you to get the speedo a little more accurate. Granted, I would do a second check just to verify the GPS as the reading on a GPS can be altered due to how the GPS satellites are timed. I have had to learn more about the GPS satellites than I care to admit to and it is possible to alter the time of each satellite which can throw off speed and relative position. Granted, this is normally done in areas where GPS guided ammunition is being used. But, even having a satellite off by say a microsecond can have a big effect on things.
What I would tell you to do is to find a nice flat, straight road that you can travel on for say 5-10 miles. On this road, set your cruise at whatever speed you want and then note how many miles you travel, also noting the time it takes you to travel this distance. You can then take 3600 and multiply it by the number of miles that you traveled and then divide it by the number of seconds it took you to travel that distance. Normally 5 miles is a good distance to travel as you are getting any errors down to fairly small percentages. This will allow you to confirm what the GPS is saying and ensure that you are going to get the speedo corrected properly.
iflashe
05-29-2012 07:08 AM
gem
07-08-2011 01:44 PM
