Got bored of my rims and wanted flush fitment, larger rims, and an aggressive stance so I went with Vossen HF-3 21 inch in gloss black.
Rim and tire specs:
-Front: 21x9 flat, Pirelli P-Zero 255/30/21
-Rear: 21x11 concave, Pirelli P-Zero 305/25/21
-These tires specs match the diameter of my old factory 20 inch rims so there's no error in speedometer ratings.
-No rubbing whatsoever, the wider rims fit no problem with the 21 inch rims, I can even go wider!
-Not sure what the offset of the rims are because Vossen does that custom from factory. Before the new rims After: 305 tires make it look so much better
Just did Vossen HF-3 wheels on my Sportbrake and love the way they look on the car. Not overstated, but still a bit more interesting that what came stock. I like them even more at 21" vs. the 20" that I did, but New England pot-holes suggested that I be a bit more conservative.
BTW, where did you source the blacked out badges?
Thank you Jack!
I think I saw your sportbrake with the Vossen rims before they look great! Yes the ride has definitely gotten a little more rougher and I have to be much more careful for potholes now but I think it’s worth it.
I got the gloss black badges OEM from Jaguar Palm Beach. They’re a little pricy but I think are worth it because I bought some gloss black badges on EBay and they were cheap and didn’t stick on well and weren’t the same exact size as the OEM badges.
