tail light x260 problem
First time hello all.
The search engine brought me to you. I have two jaguars models, I'm a jaguar fan and I hope we can become friends.
Because about my problem, the rear light no longer works (more precisely, the one on the right - the side with the passenger). It only tries to light up when braking. The position light does not come on at all, only the turn signal works. I specify the fact that two weeks ago I installed a light (LED trunk bar - it has a plug that connects to the rear tail)...I temporarily removed it now (I thought it was from her)....I checked visually if everything is fine. Can someone explain so I can check? The fuses are good, the ones in the trunk... It seems that there is water somewhere or it is an imperfect contact but I can't figure it out. to me where the right tail plug goes under the bar? is there another link? I think it's something with the water...or what else should I check?
Alice
16
11-21-2023 11:03 AM
