Water in trunk/boot
Water in trunk/boot
Anybody have a problem with their 2016 XF getting a little water in the trunk, next to the spare tire in the area just in front of the tire/tyre iron and blocks. I had a spare rag in that spot and it was soaked. I was outside a lot and under heavy rain conditions. I do know that water leaks are not uncommon in many brands of auto. Just trying to figure out where it is coming in before I take the ferry to Vancouver to the dealer. Thanks
Received 2,266 Likes
I mean, water will still make it to a boot/trunk, but it will also drain out and dry out eventually. If not, then your drain holes could be plugged by dirt.
