What do the driving modes actually do?
dynamic will increase your rev range thorugh the entire gear set. For example, your second to third gear shift will happen about 2k RPM's higher than normal. It will hold 3rd gear alot longer than that. Keeps the car in the meat of the tourque curve. Eco..saves gas by turning your engine off when stopped, cant remember what snow does, ...its all in the manual
Thanks Cherry!!
My XF is a manual so your rev range answer I guess is more relevant to an automatic.
I guess I wondered whether in dynamic you get the full 180bhp other than in normal when it may be a bit less. Also, does the suspension stiffen or does it change any other settings like that in dynamic? And I've also heard somewhere that in dynamic the car "learns" your driving style but not sure whether to believe this.
Received 3,259 Likes
I've moved your question from X250 to X260 forum. This is the place to post technical questions about your model.
(click on the images to enlarge them)
Thanks Cherry!!
The Dynamic setting firms up engine response to acceleration - trying flooring the throttle first in Eco and then in Dynamic for extreme comparisons. Suspension is also noticeably tightened. I drive exclusively in Dynamic, but always have to remember to switch over first thing in the morning. In the dark winter months it is easy because you miss the red tick marks around the speedometer and rev counter...
The Snow / Ice setting similarly cuts down the power and combined with higher gear makes driving very much safer and easier, I can testify to that.
Enjoy your XF!
