I need to replace a starter on my 2010 XFR. It’s supposed to be on passenger side, accessible underneath. Anyone have a diy or at least diagram as to where it’s located?
The manual isn't actually helpful in locating it. I think I can see it from the top on passenger side, which is not how my dealer said it's accessed. Will remove the airbox to see if I can get a better look. The dealer quoted me $775 for the part, they won't install a used part, and about $1,000 in labor. Sigh.
Thank you again guys, will throw in a $79 used starter off a 67k mile XJ and this just saved almost $2K at the ***********. Was not that hard at all once I found it, the exception being the 13mm nut by the cat that needs a ratcheting wrench and mine’s sidewall was too thick to get on, but two minutes with an angle grinder fixed that issue!
