Window rattle drivers door
I can look at the cables as suggested but struggle to see why dropping the window by a fraction of a mm would stop the rattle if the cables were the cause?
The position of the cable changes as it operates. I wasn't saying it was the cause, just mentioning that it is a common issue with rattles from driver's door.
It could be anything inside the door, suspect it to be involved with the regulator ( cables, clips attached to window - these are plastic, etc. )
Rocky15
11-11-2015 10:59 AM
Jag Pilot
07-04-2013 10:09 AM
