Windshield wiper questions
Gents: I’m trying to replace my wiper blades on my ‘16 XF. There isn’t a ton of information on the internet about replacing the blades though I’m managing to figure it out. Anyway, I looked up the XF’s wiper specs on Rain X and Bosch and it said 22” for the driver’s side and 19” for the passenger side. But when I compare the factory blades to the one recommended, it’s a fair bit larger.
Anyone know why that might be?
The other question is how you get the I&L connector to work. I think it’s actually an I&L clone with the button. Do you guys have any advice on how to deal with the windshield wipers?
I searched the threads and could’nt find anything on it specifically.
Thanks in advance!
Thanks in advance!
Yes, same story here. First rainy day with my new XF (back in September) and I couldn't believe the noise. The dealer replaced the blades after I tried several fixes. New blades solved the problem, but they still squeak a bit at the end of travel from time to time. I can't remember ever having noisy wipers, in any car, that didn't have an obvious issue. The XF had me stumped.
After hearing this complaint a few times, I'm wondering if there's a design (or manufacturing) issue with the wiper arms. Maybe it's a tension thing. Is there a service bulletin?
RGT (12-18-2018)
Maybe when I'm picking up my plates I'll have them take a look.
Another wiper related issue that came up for me: apparently you can't leave them up in service mode. When it snows heavily, especially when going north for a ski trip, and I know it's going to be snowing overnight, I always lift the blades off the windshield. In this car, that's not an option. When ignition is off, they will always return to parked position out of service mode.
As I type this, I'm thinking that the Jag comes with a heated windshield, so maybe it's not something I need to think about anymore. First heated front windshield for me
I only use it to remove fogging out of mine. Not sure if it is strong enough to heat the outer surface quickly,
Received 2,190 Likes
That's an interesting thought. I realized that the manual, which I actually RTFM'd fully, appears to not actually note what's optional equipment. So some things I find that I have and some I don't. The manual talks about every item as a given. The sales 'sticker' notes most, but not all options the car came with, so I guess some are 'Jag standard' and I'm just not familiar enough yet.
ololly (12-20-2018)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/523x737/handbook_4bf84c4ae9f69b896748489647c1fe9d14556187.jpg)
I agree that a list of STANDARD and OPTIONAL equipment should be included.
Here's my $.02..... I've had cars that the wipers 'stutter' and I've always been able to fix them after going through the drill .... blade angle, arm pressure, clean windshield (not just wipe but clean with razor blade and compound), and new blades. Never the same thing fixed the problem from one to the next but I have noticed that new blades on a clean windshield usually works for a while. I have also noticed that when lubricated with windshield washer fluid the stuttering stops for at least a while. Leads me to believe it's wiper blade rubber that's breaking down with use and airborne contamination that causes it.
jaguar has a windshield paste that cleans the glass and should be done a often as needed. And im sure there other glass cleaning compounds out there as well. I know amway sells a glass cleaning paste that works the same too. I usually just use glass spray cleaner and 0000 steel wool faster and cleaned the crap off the glass you dont see
RGT (01-20-2020)
