Xf 35t r-sport shut off when coming to a stop
My 2016 cuts off when coming to a stop lately with no warning to the point I have to put it in park and restart the car,took it to the dealer for service an a oil change at 11k miles but they did not find the issue. Has anyone else ever experienced this? It's not the eco mode because it shuts off to the point of no radio,ac, etc
I have the 2017 model year of the same car and have not experienced this issue. Are you using auto stop/start? If so, does it die after the engine has stopped as a result of the auto stop start kicking in? I am wondering whether it is as a result of a malfunctioning auto stop start function. Just a thought.
Last year my car cut off, but it did it while driving too, so I suspect your problem is different (mine issues was a bad cable to the fuel pump).
I remember someone else on this forum having an issue similar to yours in the last year. You might find that post and try to find out what their problem turned out to be,
However if the auto start stop was not in use (it had been disabled) and the car simply died when you came to a stop, this may be a completely different issue. Fuel pump, other intermittent electrical issues etc.
Sorry, I may have been misunderstood. What I was asking was did the engine stop and not restart when auto stop/start was engaged ie. with auto start stop engaged, did the engine stop as expected, but refuse to restart when you released the brake and pushed the accelerator and require a push button start instead. From your discussion this was obviously not the start stop function acting normally and I did not intend to suggest that it was. I have seen cases where when the auto stop start was engaged, the engine would not restart after a stop and require a normal start using the engine start button, in other words the auto stop start became auto stop and not auto start!! This was a software bug ( a friends 2016 XF).
It's natural to assume the dealer knows what they are doing but that's not always the case. In this instance I'm guessing the technician was paid to perform the service and not troubleshoot and intermittent problem. I know it's a hassle but keep taking it back until they fix it.
If it was not for the dealer I would much more positive about Jags, but they are hobbled by dealers who are not quite up to the job in my opinion. BMW are much better and MB slightly better but worse than BMW. Best dealers I dealt with were SaaB... Now there's a thing.
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Well just to update I gave the dealer a bad review using google and the service manager posted a reply, apologized and left his number. I called and explained my situation and he asked me to bring the car back,he'll give me a loaner and address the problem, he also said the Range Rover just got a service bulletin about the auto/stop issue and he sure it's the same with Jaguar and like it's been said a software update may be the ticket!!!
Sad that you need to complain to get what you should have received initially. My problem is not that the dealers do not eventually do what you need, they do - eventually, but you have to go through all the pain and conflict of complaining to get it done. This should not be necessary. It has become the norm to be surprised when you do not need to make a fuss. This is not how it is supposed to work. Sigh....
QwikCat
XE ( X760 )
06-21-2016 06:07 PM
Maddan
08-08-2015 07:55 AM
hawaiianjag
11-30-2012 06:24 PM
