XF climate control
Hi
I have a 2013 XF 2.2 diesel. The vents stopped opening the other night. I googled reasons for this and low battery was the main answer so I trickle charged the battery. The stop start is now working again so the battery is fully charged but the vents still won’t open and the fan won’t come on. The outside temperature reads as blank on the climate control. Have also tried disconnecting the battery which made no difference.
any help and suggestions appreciated.
Lindsay
Lindsay
fuse board replaced and water pump for screen washer replaced. Cost £1250 at Sandeman’s Forfar. Fuse board was £575 then VAT on top!
Car now running like a dream.
Hope this helps.
johnnywishbone
XF (X260)
11-19-2019 09:09 AM
