XF X260 2.0d Loud tapping noise from Engine
Hi all,
My Jag XF X260 2.0d has been making this loud tapping (Please see attached video) knocking noise for a while now. any suggestions on what it could be?
I have had the oil and filter changed also checked the injectors with a long screwdriver and they seem to be firing and working fine. Any ideas or suggestions would be greatly appreciated.
https://vimeo.com/user120062230/revi...156/f9d9096e8e
Thank you all.
Thank you all.
Your link doesn't work. What year is the car and how many miles ? Who maintains it and do you personally check the oil level at reasonably frequent intervals ? The service interval on these cars with diesels is far too extended IMHO and an owner really needs to make sure he carries out whatever the Owner Manual recommends for regular checks.
Unfortunatly,the oil level was not checked for about 6 monghs....
The link seems to be working for me but I have attached a clip with this reply.
Thanks again.
I beleive there were issues with the timing chain and its tensioners in early engines. Is the noise coming from the rear of the engine ? Noises like this are very hard to determine with diesels as the combustion in the cylinders makes a knock as well. The old diesels were really clattery before the techies got onto it.
