[CRITICAL] Restore original CCF configuration "As Built" after unsuccessful result
Hi guys & I've read a lot around if it resonates with my problem but no luck,
So I'm in a critical situation now, because my car logged several errors & won't even start the engine after an update to CCF ( after I got the password to access).
All I wanted is to upgrade the Amplifier from Mid to High after I fitted in the High model which is compatible with XF 2012.
Eventually after update on CCF, here are modules & errors:
Is it a communication issue with those modules during update ? The battery was yellow & probably low voltage, it seemed quick to download the configuration & apply it, but after care restart here is the state:
here are the missmatches with "As Built" eventually:
here it proposes me to run the the Extras of errored modules, but I wait for my battery to fully recharge to try these (will post later):
What can be done ?
1. Can "As built" CCF configuration be restored ? I know it's an .XML file in "/ProgramData/JLR/IDS/Sessions/SOFTWARE_MANAGEMENT/SM_AS_BUILT"
2. Should I restore back the values & try to re-download a new config ? But I'm afraid it will still log those errors & critical modules.
3. Would a hard reset of battery ( disconnecting ground for 10 min ) help ?
[ASAP] Please advice & help.
Anatolie
What can be done ?
Anatolie
I noticed those modules just failed to download because for some reason the wrong parameters are set in CCF for PowerTrain, Transmission etc. - all those crossed red modules, so communication with them can't be established, hence the car can't start the engine.
Why there was ? question mark in the value parameter ?
I don't know the right value & if it can be edited ..
so that explains the red crossed unable-to-communicate-with modules.
Where can I see the right values for PowerTrain modules from "As Built" original state ?
No, I tried posting the value CX2314D628AG for example instead of CX23?14D628?AG & it still inserted ? as it means the dash probably.
So it leaves me with the question, why it can't communicate with those red modules - ABS, GSM, PCM, RCM, TCM, AAM, ACM, IPC ?
Why it can't download or match the appropriate .vbf file for them ?
Thanks for noticing, basically no stable supply of 12.5+ yet.
Just starting the engine when I need to Run a configuration + a battery charger (but it's weaker) to reach green.
I know about 13+V constant but not yet possible.
Eventually fixed all the errors after Security Authorization procedure.
But my main problem resonates with "AAM -> no sound" because I unaware ran "Configure new module" after I plugged the BJ32-19C164-AF High to my Mid.
So now I try desperately to localte/find/obtain the matching .vbf calibration/firmware files for this amp: BJ32-19C164-AF.
Any help?
Any help?
Rbrites (12-28-2023)
Any help?
Any help?
Having the same issue... did you go through all of the authorization to solved it.. I will give ot it a try I did the HUD module update and after car wont Start
Naso--Lituratus
04-02-2015 10:44 PM
