10 inch Tesla headunit upgrade with install video
#282
Hello Denis,
I'm coming back to you because I still haven't found the solution to my 4G connection problem.
Access or modification rights are systematically blocked.
The seller tells me that he has never encountered this problem and, according to his words, is also looking for the solution.
Cordially
Cordially
#283
Hello Denis,
Cordially
Cordially
All European SIM cards come preinstalled with a SIM PIN, however on our Units there's you're not asked to to enter the PIN when it starts so the SIM card is Locked.
Solution is to put the SIM in your phone and in the settings turn off the SIM Lock. Then put it in your car and enjoy 4G
Hope this solves your problem.
#284
#286
Yeah. This is a big problem with the vendors. They don't know jack. I am working my no hazard light problem with these guys now, and I am communicating with the vendor who then communicates with the engineer. This is making it take longer, plus the questions they sometimes ask make me wonder if they even have a unit assembled to work with. I wish they would just send me the schematics for the head unit, and let me try to figure it out myself.
#287
#288
Just wondering if anyone has found a way to change the time in the centre of the dash? Luckily today we're changing back to Sommer time here in Europe which means mine will be back to the correct time 😁 but what happens it the battery is disconnected?
#289
#290
Hello,
My car radio is now fully operational. I still have a question about the display setting.
Let me explain, I have a video application that is displayed in full screen but the adjustment buttons are located under the air conditioning adjustment strip.
Is it possible to hide the banner or how to adjust the display.
thank you for your reply
#291
I finally got my unit today as well... all of the below was included.
Surprised to see that the trim plastics were actually hydro dipped to mimic wood... and button for the glove box was included with some trim removal tools as well :|.
What are these wires for!?
Adapters to use the existing car's wires or something else!? What do I actually need to connect from this mess? lol
Should be interesting...
It had a video camera included as well, but is not in the pictures. Unless someone has like a DIY on how to wire it, I have no idea how to for now .[/QUOTE]
Please, could you tell me the link of your supplier?
Seems they're fixing some issues, like wood trim aspects.
Thanks in advance
Thanks in advance
#292
What year vehicle do you have, do you have a factory backup camera, if yes the unit has a wire to plug it in,watch my old video how to install it,4 parts
https://youtu.be/nlyY9kiXqr8
you can also vinyl wrap it
https://youtu.be/WxO50BSZW1Q
#293
Just saw this. Were you referring to me about the hazard lights? I have a 2012 XJL rather than the XF. No connector like that. The connector that has the hazard signal comes in on a flat connector with motherboard. The last picture in post number 291 by agcb is the connector I have, with the exception mine only has 2 wires. I am suspecting that the other wires not being present on mine might be the actual problem.
