10 inch Tesla headunit upgrade with install video
Old 04-12-2021, 05:45 PM
Oxidizer2k's Avatar
The plastic trim they include, does it include a button as well to open the glove box?
  #42
Old 04-12-2021, 06:09 PM
dennis black's Avatar
No button, you just simply remove the 2 screws on your original one and put the button in the plastic one , What you see is a mock up of a old spear i had from an older model with no hole ,so i got one for a 2015 with a hole for $25 and ill mod that like you see, i just wanted a little practice before my good comes ,
K. Kent (07-08-2021)
  #43
Old 04-12-2021, 06:59 PM
Carlos Saez's Avatar
I thought of the same solution, getting a spare spear and cutting, how did you cover the edges after the cut?
  #44
Old 04-12-2021, 08:11 PM
i cut some black plastic , and put some vinyl wrap on it so it looks part of the car, when cutting put tape on it so you get a clean cut
John Williams (04-13-2021)
  #45
Old 04-13-2021, 04:37 AM
Taffyduck's Avatar
Originally Posted by Sean W
I think you're referring to the pictogram from the sensors? That signal is fed through the can bus IIRC. The cable that connects to the OEM touchscreen is the rear camera
That's correct, the picture of the car with just the sensors. So if this comes from the canbus then in theory it could be activated on the new Units or am I missing something?
Until then I might get a wireless camera for the front.
  #46
Old 04-13-2021, 08:47 AM
Sean W's Avatar
Received 4,275 Likes on 2,392 Posts
As far as I can tell right now, the can bus decoder is only interfacing with what is available on the OEM touchscreen and even there, not everything. Also supports the steering wheel functions but again - the heated sw is an issue. On my XK, Valet mode is gone as is the ability to clear DTC codes.
Sounds like on your vehicles, the front sensors don't work with the aftermarket unit and you only have one video input into the new head unit? Is that accurate?
If it is, you could in theory, get a can bus sniffer and ultimately modify the code. You still need to connect front sensors or dash cams to the aftermarket head unit. So that would require hard wiring to the new head unit (God knows where), or wireless and then coding of the aftermarket system to automate it.
Carlos suggestion is the practical solution. One of the units I looked at supported an optional front camera that connects to one of the USB cables,
  #47
Old 04-13-2021, 11:01 AM
Taffyduck's Avatar
You are correct, only video from the rear camera. Which means I'll probably go down the route of a wireless reversing camera, just for the front 😉
  #48
Old 04-13-2021, 04:11 PM
they give you a extra camra for the front and a option button to turn it on
they have multiple video inputs for cameras
acgb (05-13-2022)
  #49
Old 04-13-2021, 09:57 PM
Taffyduck's Avatar
Don't believe that comes with my unit 😔 could you let me know what camera it is 👍
  #50
Old 04-15-2021, 08:10 PM
it came in this bag
front camera
  #51
Old 04-17-2021, 11:14 AM
Taffyduck's Avatar
So my unit came today and after some baffling moments and having to pimp the brackets all is in🎉 just one really big issue and that is the car information panel in the dash is in Chinese although everything else on the unit is in English. So if anyone knows how to change it I'd be very happy 😁
  #52
Old 04-17-2021, 11:16 AM
Taffyduck's Avatar
  #53
Old 04-17-2021, 02:34 PM
You got the wrong brackets, the ones on top and bottom, are for prefacelift, i can see from your pictures that the problems still remains.
  #54
Old 04-17-2021, 03:13 PM
Sean W's Avatar
I'll ask because you don't specifically state it or maybe I missed it. Did you go into settings and select English? I understand since everything else is in English and I would expect the gauge cluster to be the same.
  #55
Old 04-17-2021, 04:47 PM
Taffyduck's Avatar
Yep, everything is in English. If you go into vehicle settings where you can change the settings for the heated seats etc, at the bottom there's the option for language, but no matter what I select nothing changes😔
  #56
Old 04-17-2021, 08:56 PM
nice job bud
Testing boot up speed
The following 3 users liked this post by dennis black:
envincibal (04-18-2021), K. Kent (07-08-2021), Oxidizer2k (04-18-2021)
  #57
Old 04-18-2021, 09:41 AM
Taffyduck's Avatar
So I've took out everything today and found out the Problem with the Chinese is from the Canbus decoder. As you can see from my video the dash display is in English untill the canbus decoder is plugged in then it goes to Chinese. As Denis is not Having the same issue with his facelift model I would imagine the canbus decoder is defect or it's the wrong one.
Attached Thumbnails 10 inch Tesla  headunit upgrade with install video-canbus.jpg
  #58
Old 04-22-2021, 08:39 PM
trying different carbon fiber wraps
  #59
Old 04-23-2021, 07:29 PM
finished vinly wrap ,next going in the car
THC_Jag (05-20-2022)
  #60
Old 04-23-2021, 07:49 PM
You got a heated sterring wheel button now, is that with the XK model, we are getting it in the small unit if we select XK model don't know if it works.
Quick Reply: 10 inch Tesla headunit upgrade with install video
