'11 XF Premium - Abrupt gear change when stopping
A big howdy from Texas! The past month or so I've noticed that when I'm almost to a full stop, my XF jerks like it's changing gears from 2 to 1. It became so bad the past couple of days that I've resorted to manual shifting so that it starts and stops on 2.
Has anyone else encountered this issue? What's frustrating is that it's intermittent. I'm concerned that when I bring the car to the dealer they will say that they can't replicate the problem.
Thanks in advance for your help!
I can confirm that my 2010 XF Premium exhibits exactly the same thing. I have complained to the dealer and they came back with the fact that all is normal. It seems to occur, for me, when I come to a slow stop from a reasonably high speed. It always happens in the final moment of the stop. It is exacerbated by the brakes that need careful modulation to get a smooth stop.
I always drive mine in Dynamic Mode with the trans in S and use the paddle shifters, the car always come to stop in 2nd gear, if I manually shift it down to first once it is stopped I do feel it select 1st gear. Seems like it wants to take off actually and the brakes are holding it stationary. Starting from a stand still in second gear actually works very well with a nice smooth start and you can hold the gear longer, 1st gear on these cars seems very short.
I notice it more when I decelerate slowly, brake gently, as in rush hour crawl. Doesn't feel unhealthy. Just downshifting early enough to give a boost to engine braking.
Our 2003 Honda Odyssey had a tranny failure at 60kmi. It started "slam shifting". My wife thought she was rear-ended. If yours shifts violently, then you likely have a real problem.
Aaron,
I had the dealer reset the adaptive trans - its not as bad but still doing it - weirdly there appears to be no "pattern" to the problem. sometimes it does it sometimes it don't.
What does the future hold for this problem - will it get worse or better - who knows-
This is not acceptable from someone that has had at least a dozen Jaguars and Mercedes.
Does it justify - buy american???
By the way my car is a 2009 in lunar grey with grey interior - a real looker especially with the 19 inch wheels.
Rocco
Rocco
Hey Rocco. I want to tell you mine got progressively better but I don't think it did really. Maybe slightly but unnoticeable really. I had it reset and it stopped almost immediately however would still do it maybe once on a 30 minute drive through the city. It is definitely down to about once every 5th time I get in the car so maybe it is still "learning" or maybe I am? Nonetheless I hate to say it but it fixed the problem for me.
I know what you mean though, this being my first Jaguar I anticipated nothing like this (although fixed now) it was surprising at first. When I initially brought up the issue with dealer they mentioned how this is common with the Jaguar as well as Land Rover (certain models but can't remember which they said) however still doesn't excuse it.
I guess you can see mine in my picture but lunar grey with black interior and 20" Selena's. Can't say I have had a ton of lookers, it doesn't catch your eye but once you focus on it you can't turn away. I have parked it outside restaurants and have seen people walk around it admiring it which is a new experience for me. I am interested to see some pictures of your especially with the grey interior.
Thanks for the update.
Aaron
Aaron
MC36
US Lower Atlantic
09-01-2015 07:34 PM
