19 inch wheels that fit XF SC?
Does anyone know of any aftermarket or OEM jaguar wheels that fit the over the XF SC brakes. I know cwood as an OEM set that fits but haven't found any of those. I called Coventry who is owned by TSW and "made for Jaguar" They said none of their 19 inch wheels fit the XF SC and recommended staying with non-staggered 20's as many winter tires are made in that size.
I was hoping to keep the cost to $300 or so per wheel.
Thanks in advance.
Thanks in advance.
I know the jaguar XK 19" wheel works just fine, and clears my XFR's huge brakes.
This was the size and style,look for the knock offs
Jaguar XK Tamana 2010-2011 19" x 8.5" Factory Stock Wheel Rim | eBay
jaguny (10-02-2012)
I had TSW jaramas on my Lincoln LS, which has the same bolt pattern as the XF. 19" TSW Jarama Silver Wheels 5x108 Volvo S40 S60 S80 V50 Jaguar S X XF Ford | eBay
jaguny (10-02-2012)
Came across another aftermarket that I am told fits the SC besides the Niche Circuit.
Ace Alloy Executive. Comes in several finishes. 19 x 8.5, ET 45, with 5 x 108 bolt pattern. Would need hub rings.
To summarize in addition to these two aftermarket wheels, the two OEM's that members have used are the Tamana and the Auriga.
XK8 uses the old XJS platform, not Ford hubs. Unless the Internet is wrong.
Older generation Jaguars use a different hub from the S-Type Ford based line.
XJ was next to switch to Ford based hubs, then the XK and finally the XF. The X-Type was just a Ford Mondeo and doesn't count as a model which "switched".
The new XK is Ford based. The old XK8 is not.
You were asking about stock XF wheels not XJR wheels correct? Checking a stock XF wheel is easy for a dealership as they have access to them as well as the SC. If you buy your XF SC at a dealer I am sure you could get them to check it for you by testing with the stock cars they have on hand and the car you are going to purchase.
