19 inch wheels that fit XF SC?
Old 10-01-2012, 07:52 PM
jaguny's Avatar
Default 19 inch wheels that fit XF SC?
Does anyone know of any aftermarket or OEM jaguar wheels that fit the over the XF SC brakes. I know cwood as an OEM set that fits but haven't found any of those. I called Coventry who is owned by TSW and "made for Jaguar" They said none of their 19 inch wheels fit the XF SC and recommended staying with non-staggered 20's as many winter tires are made in that size.
I was hoping to keep the cost to $300 or so per wheel.
Thanks in advance.
Old 10-01-2012, 08:42 PM
cwood's Avatar
Did you try Detroit Wheel and Tire?
jaguny (10-02-2012)
Old 10-01-2012, 09:11 PM
BigCat09's Avatar
I know the jaguar XK 19" wheel works just fine, and clears my XFR's huge brakes.
This was the size and style,look for the knock offs
Jaguar XK Tamana 2010-2011 19" x 8.5" Factory Stock Wheel Rim | eBay
jaguny (10-02-2012)
Old 10-02-2012, 12:00 AM
XF - Xtra Fast's Avatar
Sorry to thread jack but what about 18" wheels all the good drag radials are 18". The 2" drop in wheel diameter should allow for some sidewalls that can actually 'wrinkle' and maybe some real quick 60' times
Old 10-02-2012, 12:03 AM
Executive's Avatar
I had TSW jaramas on my Lincoln LS, which has the same bolt pattern as the XF. 19" TSW Jarama Silver Wheels 5x108 Volvo S40 S60 S80 V50 Jaguar S X XF Ford | eBay
jaguny (10-02-2012)
Old 10-02-2012, 04:39 AM
jaguny's Avatar
Having difficulty with the 19 inch size clearing the brakes. Do you know of a manufacturer(s) and/or specific wheels that will fit over the SC brak
Old 10-02-2012, 04:40 AM
jaguny's Avatar
I will take a look. Thank you.
Old 10-02-2012, 04:43 AM
jaguny's Avatar
I will put this on my list of possibilities which only has this and one other on it (Cwood's winter wheel choice). I was hoping to find a black machined or a black center with ss lip rim. Thanks.
Old 10-02-2012, 08:12 AM
Executive's Avatar
jaguny (10-02-2012)
Old 10-02-2012, 06:17 PM
jaguny's Avatar
I found an after market wheel that is I am told is a guareented fit, Niche Circuit.
It's a 3-1/2 week lead time. Price isn't bad. Still shopping if anyone has any other wheels that fit.
Old 10-02-2012, 07:43 PM
jagular's Avatar
This is wrong because the XK8 uses a much bigger bolt circle than the XK, XF and newer XJ.
Old 10-02-2012, 08:13 PM
Executive's Avatar
No they are not.
Old 10-05-2012, 06:16 PM
jaguny's Avatar
Came across another aftermarket that I am told fits the SC besides the Niche Circuit.
Ace Alloy Executive. Comes in several finishes. 19 x 8.5, ET 45, with 5 x 108 bolt pattern. Would need hub rings.
To summarize in addition to these two aftermarket wheels, the two OEM's that members have used are the Tamana and the Auriga.
Old 10-10-2012, 09:42 PM
FirehawkMike's Avatar
do stock 18" xf wheels fit on an xf supercharged. my xjr was just declared a total loss in an accident and am conidering moving to an xf sc
Old 10-11-2012, 08:16 AM
jagular's Avatar
Originally Posted by Executive
No they are not.
XK8 uses the old XJS platform, not Ford hubs. Unless the Internet is wrong.
Older generation Jaguars use a different hub from the S-Type Ford based line.
XJ was next to switch to Ford based hubs, then the XK and finally the XF. The X-Type was just a Ford Mondeo and doesn't count as a model which "switched".
The new XK is Ford based. The old XK8 is not.
Old 10-11-2012, 06:27 PM
jaguny's Avatar
I thought I had read here on the forum that someone was running 18's on a SC, but I am not sure. The brakes on the SC are quite large. I would call your nearest Jag dealer and ask. The sales people at my dealership were more knowledgable than service as they tend to handle the newer customer follow up.
You were asking about stock XF wheels not XJR wheels correct? Checking a stock XF wheel is easy for a dealership as they have access to them as well as the SC. If you buy your XF SC at a dealer I am sure you could get them to check it for you by testing with the stock cars they have on hand and the car you are going to purchase.
Old 10-12-2012, 12:55 AM
yes was talking about stock xf wheels. I was running them on my xjr, since you needed the wider rims with the brembos on the r.
Old 10-12-2012, 05:06 AM
jaguny's Avatar
Since you own them, this should be an easy check on the XF SC at the time of purchase.
Old 11-23-2012, 07:05 PM
jaguny's Avatar
The 19 inch Ace Alloy Executives DO NOT FIT. First set shipped from Discount Tire was the wrong wheel altogether. Second set shipped with 45 offset did not fit. Third set shipped with 35 offset still did not fit. Starting over. Not a good experience with "guaranteed fit".
Old 11-23-2012, 07:30 PM
cwood's Avatar
Understatement! Must be very frustrating!
Quick Reply: 19 inch wheels that fit XF SC?
