1st DIY Service
1st DIY Service
As my XF is out of warranty, I decided to have a go at DIY servicing, to save on Jaguars servicing costs. I'll be changing the oil regulary, so I've invested in a Sealy oil pump to make the job easy, £35 off Ebay for a 8 litre pump. The 2010 car has a dedicated extraction pipe to the bottom right of the engine cover, apparently this runs to the sump bottom, so virtually all the oil can be sucked out.
So I got started early this morning and with minimal effort, the pump was sucking out the oil at about a litre a minute, right up until you could hear it suck up the final drops like finishing off a milkshake.
In total, I replaced 7 Litres of Mannol Jaguar Spec Oil, Mann Oil filter, Delphi Fuel Filter, Mann Pollen filter and upgraded to a new K&N Performance Air Filter. All other fluid levels have been topped up and the usual checks done. I also cleaned both MAF sensors with Electrical Cleaner, one was really dirty. Finally I cleaned the air intake system to avoid any future dirt getting on the MAF. The K & N air filter seems to be working fine, I expected an increase in engine noise, but it was actually running quiter and smoother.
I added my secret weapon, Archoil 9100 oil additive, this stuff is excellent for diesel vehicles. I'm also running Archoil 6400 D Max through the fuel system. The is Engine sounding very sweet. Will have to see what MPG I get now, as I was only getting on average 28mpg mixed driving pre-service, I was hoping for a least the low 30's when buying the car and 40's on motorway.
The only thing I'm concerned about, is that 7 litres of dirty oil was pumped out of the car, in fact a bit more then 7 came out!! I believe the recommended amount is approx 6.5 litres. Following this guidance, I initially put 6.5L, but the electronic guage, told me to add another half litre, so I did. So in total I've put 7 litres back in and the eletronic oil level gauge is now saying Oil Level ok but showing the bar is full to max. Hopefully all should be fine but would welcome opinions and I can suck a bit out if needed..
A few photos of todays effort :
Received 3,229 Likes
After lots of mucking about with various types of filter removal tool and making no progress at all I finally found a tool that worked - a "strap/wrench style" with a rubber piece which gripped the filter. However, checking auto parts stores online & eBay I can't find a link to one!
On the 5.0 V8 the oil extraction tube is in the centre of the oil filler hole, on the 3.0 diesel it's near the top front RH corner of the motor (looking from the front of the car) and not at all easy to spot.
Edit - made a boo-boo - they don't use the same oil filter!
Long Islander (04-25-2017)
