2.0t Crankshaft position sensor
I haven't seen the 2.0t engine but the crankshaft sensor for pretty much every modern engine reads a sensor wheel which is mounted to the flywheel, so you need to be looking for something mounted around the join between the engine and the transmission. Probably underneath or at least low down on the block. Usually only held in with one bolt, should be easy to identify as it'll match your replacement part.
adam699
02-23-2016 02:55 PM
BKSinAZ
11-02-2015 10:15 AM
relaxed00
03-10-2012 04:53 PM
