I can confirm Kasuga from XJLR fits to XF SC V8. even with one profile up (I use 35 for rears and 40 for fronts) they seems a bit bigger for some reason comapring with stock Volans.
I'm surprised so few people choose to upgrade to Kasuga's. Granted they are a little hard to come by, but I think they properly set the XF off.
Anyway, here is a pic I took from a recent photoshoot. The rest of the pics can be found in my post on the official picture thread.
Tire are PS4S sized 255/35R20 front and 275/35R20 rear, so essentially stock XF sizing for the front and stock XJ sizing for the rear. I originally wanted to run stock XJ sizing for the front, but from the few posts I managed to scour up, it seems to rub on lock with a 40 series sidewall in the front.
Wondering if anyone's put on a set of the 20" XJ Kasuga rims on an XF.
I've got a '12 XF base and was curious 1) if they would fit, and 2) if anyone has any pics of an XF with them on.
I'm digging how they look on the XJ, and wanted to keep somewhat of a stock look to my XF with going with these rims.
Thanks all,
J
Yes they will. I have a 12 XF Supercharged. I don't have any problems with clearance. The XFR-S Kasuga rims are wider on the rear and some have 21in on the rear.The only problem I have encountered is the inside of the rims cracking. I've had to replace 3 rims in 8 months. I run 36psi on Michelins. Any help with the cracking would be great.
Hello.Do you have pics with your XF on Kasuga? Wheel stand out over wheel archs or it is on border line? Thank you
