2007 XK wheels on XF
Received 3,239 Likes
Yes, they will fit, but I believe they have quite different offsets to the stock XF wheels, especially (or maybe only) the rears, so it's possible that they may stick out a bit too far past the edges of the fenders.
That said, pretty much all the stock XF wheels sit well inboard and there is plenty of room to move with different offsets before that becomes a problem.
I put 30 mm spacers on the rear of my old XFS with the stock 18" Venus wheels and they stuck out maybe 5 mm past the fenders, so in hindsight 25 mm spacers would have been perfect. Based on that you should have 25 mm to play with at the rear.
Update - did some checking - the base 2007 XK wheels are the same offset as the base 2010 XF wheels, ET +49, and the 2007 XKR wheels are the same as the 2010 XFR wheels, ET +45.
So you should have no problems at all.
No, I believe not. XFs have 5 lug 4.25 inch or 108mm High Positive Offset wheels and XKs have 5 lug 4.75 inch or 121mm High Positive Offset wheels.
Jaguar - it's not an automobile, it's a Motorcar
2015 JCNA National Slalom Champion Class M
Current: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past: '05 X-Type 3.0/auto Jaguar Racing Green
>Well I rolled the dice and bought them and fit perfect!
Good on you! There sure seems to be a lot of conflicting info on Jaguar wheels for the various models. Nice to know that someone did an actual check.
My car is wearing ~2010 XF 18" wheels
Jaguar: Grace, Pace, and Space - Sir William Lyons
Current: '08 Jaguar S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
I think the rear offset sticking out that much doesn't look great, especially with the fronts being in quite a bit more.
Maybe if you put spacers on the front to even it out, but not sure that would make everything look right with this style of car. It's just not a Dodge Charger.
dont you have somewhere else to be?
I don't care who you are that's &@$!'n funny right there!! And then you come back with the gayest freaking come back ever. ROTHFFLMAO!!!!!! Goes right along with that fairy color of car you got there too, bro!!! Keep em comin' ........
![Icon Vp](https://www.jaguarforums.com/forum/images/smilies/icon_vp.gif)
![Icon Lolsign](https://www.jaguarforums.com/forum/images/smilies/icon_lolsign.gif)
i wouldnt be super pumped about driving around a Lambo thats a mere .2 sec faster in the 1/4 than my 4 door sedan.... and thats with someone that knows how to drive...id put you at about .3 slower : )
