2009 4.2 V-8, oil in intake manifold
I recently had to remove the intake manifold from my 2009 XF, with the n/a 4.2 engine, so I could replace the coolant hose that loops under it. I set the intake manifold on it's back, on the workbench, so I could remove the original gaskets, and then install the new ones (they clip in place, on the manifold). When I flipped the manifold back over, oil started dripping out of the passenger side, front port of the intake manifold. All told, about 1-2 ounces of oil poured out. I cleaned out what I could, and re-installed the manifold. Car is running fine.
Is this indicative of a PCV issue? Is there something that I need to clean out?
TIA!
TIA!
ltshaneclarke
10-23-2018 06:24 PM
hankuruski
21
01-30-2012 01:16 PM
xjrwithproblems
10-20-2011 11:58 PM
BugDoc
03-07-2010 03:24 PM
