2009 Backup Camera Issue, help please
I've searched this forum, tried doing research before posting a noob question so I'm sorry if this is somewhere I haven't looked.
2009 XF S/C, when you put the car in reverse the screen goes blank/blue. It worked when we purchased the car for about a month. I removed the upper trunk liner for inspection, where the camer is on the outside, there is nothing on the inside.... Hmmm, wonder if that whole panel comes off from the outside of the trunk lid? I'll look into that, but in the mean time, had anyone dealt with this issue before?
Thank you in advance for everyones time reading or replying to help me tackle this issue
Don
Don
The camera uses a coaxial cable to transfer image info. Remove trunk lid liner and look for coax cable. The coax cable needs to be measured for continuity between rear of car and at touch screen. Sounds difficult but not very hard. Have found issues with cable and not camera.
Otherwise to the other members this is a factory system that came with the vehicle new, not an aftermarket add on
The rear light wiring will follow the same path, generally, as will the electric trunk release. If you can see no wiring you are looking in the wrong place. Bear in mind that the trunk lid is two part, inner and outer, made from aluminum. The wiring is probably fished through between the two metal parts, the liner and the skin, and may only be visible at each end of the wiring pathway.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
