2009 jag xf trunk issue
Using the smart key doesn't allow me to open the trunk plus the button by the steering wheel. Could it be an electrical problem? My dashboard indicates that the trunk is open, which isn't the case.
Any pointers on how to approach this situation? Any help is very appreciated.
There is a mechanical key slot under a black plastic cover underneath the boot lid plinth. The mechanical key is inside the fob.
Your issue, if neither the fob nor the dashboard switch work, is failure at the trunk solenoid right at the latch. Probably the warning message is related to this failure.
Ziggybeben
08-30-2015 02:09 PM
