2009 Jaguar XF acceleration issues.
lotusespritse (06-19-2024)
If you've no messages use OBD:
1. do not clear codes
2. any pending codes other than P1111 or P1000? (You want P1111)
3. check OBD monitors - are all set (will be confirmed by pending code P1111)
if any are not, which?
4. watch live data in the hope you see an oddity
(might be a wrong temp or air leak or ...)
In case you have P1000 then each unset monitor means a ton of codes which can't be flagged.
Had a similar issue with my XF . After a lot of troubleshooting, found that one of the impeller blades of turbo had broken and got stuck in causing it to not function. Turbo had to be replaced.
