2009 XF 4.2 S/C Differential
Hey guys,
I recently was in an accident, I was rear ended and the car has started to leak differential fluid.
The impact didn't seem too bad, the Mercedes that rear ended me took heavy damage, my Jagaur got screw divits into its bumper and a tone of scuffs, also broke the bracket that holds the bumper.
Now the leak is coming from the left CV shaft from the diff, the seal was replaced and now and in a matter of days it smelled again, and now the shaft is moving up and down.
It seems im stuck with rebuilding the diff, or finding a replacement, my vin ends in r13824. It seems I can't use 2010 diffs and I definitely can't find any from a 2009.
Insurance is a scam up here, they want me to only use their body shop and they don't have any mechanics there that can actually do repairs other then body work.
You may be stuck with a problem that can't be solved. Search the forum, there are threads about problems with early XF differentials. From what I remembered the entire rear axle had to be replaced. Unfortunately, Jaguar ran out of replacement parts years ago, there is no fix for this problem, replacement seals begin leaking immediately.
Good luck
Jaguar - it's not an automobile, it's a Motorcar
Current: '15 XF (X250) Portfolio AWD 3.0 (it's aubergine...)
2018 JCNA Class N Slalom 2nd-Place
Past B: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
2015 JCNA Class M Slalom Champion
Past A: '05 X-Type 3.0/auto Jaguar Racing Green
Good luck
Good luck
Good luck
