2009 XF coolant bleed screw?
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Hi,
Changed the coolant expansion tank because of a broken nipple. I can't get the air out of the coolant system. I've tried running with heat on and pumping the hoses. Can't get the cabin heat up. The expansion tank stays full. Car over heats if driven. I don't see a bleed screw on the passenger side lines. Any help appreciated.
jag79
16
01-17-2015 11:50 PM
