2009 XF premature tarnish of chrome door trim
Old 02-06-2012 | 05:37 AM
Herbie1's Avatar
Default Poor "chrome"
The problem with trying to polish the tarnished "chrome" is that the chrome is on the underside of the plastic trim (subsurface). Polishing will not work because the chrome is hidden beneath the outer layer of plastic. All you can do is either live with it or replace it with the same cheap junk, which is not what one expects from a premium brand.
Old 02-06-2012 | 06:18 AM
See post #5
Originally Posted by Watchgeek
All,
I worked for a company who manufactured trim for numerous car manufacturers including Acura, Toyota, Nissan, Chrysler, gm and others
The process is called "plating on plastic" and it involves forming the plastic parts using polymer materials which are formed into the specifc part , then inserting these parts in a bath of chemicals which include metals such as gold, silver and others.
When the process is completed you cannot tell the difference between stainless steel and plastic other than the weight.
They can become cloudy if the chemical process is flawed and the acid rain can affect these parts if the process at the manufacturer was not robust enough. Plating on plastic is a "science" and as a result can have many variations in product quality.
Hope this helps.
As both watchgeek and Herbie1 have said in their quoted posts above, I believe this to be true and factual.
My experience as per post #5 albeit on an Audi is that the trim is in actual fact plastic plated to look like chrome.
This was told to me by the very experienced parts manager after I managed to get them to replace 3 sets under warranty.....They have ALL went exactly the same way, no matter what I did!
Old 02-06-2012 | 09:47 AM
Fraser Mitchell's Avatar
I think there may be a plastic coating on top of the metallic bit, so metal polish has no effect. Plain old stainless steel is easy to polish and I found some of this on my prvious car, a Rover 75, but other "chrome" was actually of the plated plastic variety. But I didn't get any corrosion with it during the time I had it.
Old 02-06-2012 | 10:06 PM
buddanos's Avatar
Default That's no Plastic!
I don't know what you guys are talking about?! I used my polisher with Swirl remover and then covered it with paint sealer, wiped it and it is as good as new! The Jaguar dealer was stunned today when I showed him the result, I did half the trim only to show the difference. One thing though, you will need to tape the surrounding paint work. The polishing piece turns dark, almost black, maybe it removes a layer, but the shine is as new!
The plastic covered trim is the one notoriously used in BMW and other German cars, fades, and it is covered with a layer of clear plastic that fades also or gets dull by time. That, you have to replace.
Old 02-07-2012 | 09:17 AM
SCMike's Avatar
This is getting more and more interesting. What is this stuff? After the dealer replaced all my old trim, he threw the old pieces into my trunk. So I have got stuff to experiment with off of the car. So far, I have only had time to take a quick look. The pieces are "bright" on the underside as well as the side that is usually visible. The underside is just not as glossy as the exterior side. I took a sharp knife edge to a section of the underside and quickly managed to scrape off the bright top layer - it's soft. Underneath, is a different material, but what that is I am not yet sure. It is all clearly non-ferrous since a magnet absolutely does not stick to any of it. I will dig further when I have time.
One thing I do know about the S-Types is that the trim work details changed in the later models from that in the pre-facelift cars (mine is a 2008, hence a post-facelift). In the pre-facelift cars, the bright strip is significantly narrower and looks to be "set into" a "carrier" piece. In the post-facelift cars, it is all just one single, wider bright strip (and looks just like what seen on the current XF and XJ). Admittedly I have had a small sample to draw upon, but I have yet to see a single pre-facelift S-Type with tarnished trim - they all look fine even though they are the older models. I have seen lots of post-facelift cars (mine included) with tarnished trim. So it looks like something changed along the way.
Old 02-08-2012 | 03:21 PM
user 2029223's Avatar
Banned
Whatever the material is, it is very hard and does not respond in any meaningful way to any liquid product I have tried. I have tried various polishes, rubbing compounds and Bar Keepers Friend. Nothing touches it.
Well it's a funny thing. I have assumed, (sorry about that Sgt. Artum) that just because I had this impossible problem on my 05 XKR that it would be equally intractable on my ) 07 XK. Not so. worked on the trim with Turtle brand auto polish and "presto" the stains came right off.
Maybe the issue is, in part, waiting too long.
Old 02-14-2012 | 05:09 PM
lotusespritse's Avatar
I am getting my trim replaced under warranty later this week. The dealer tried to buff it, and they were successful in improving the finish, but it became clear that they might hurt the car and it's just better to replace it.
So, to answer everyone's question: It is aluminum (not stainless, not plastic) that is anodized. See attached to confirm from the horses mouth.
Also, notice how Jaguar will get themselves out of the warranty if you try to fix it yourself. So don't do that unless you are out of warranty.
My service adviser said it's about $600 in parts to do both sides.
Originally Posted by tarhealcracker
This thread and others like it has been running for years. The question for me is:
What is this trim material?
Chrome
Aluminium
Stainless Steel - which incidentally is no such a thing
ScotchBrite pads will get the stains off but then you can't get the cut lines out. I know there are metal polishing firms out there who could deal with it but you must take the trim off the car. One kink or dent in the removal process and you just bought yourself new trim anyway.
Replacing the trim, warrant or no, is a short term solution as the staining will be back soon enough. Can it really be this hopeless?
Attached Thumbnails 2009 XF premature tarnish of chrome door trim-photo-23-large-.jpg
  #28
Old 02-15-2012 | 06:23 AM
Banned
Does anybody else find it troubling that instead of putting out a bulletin on how to fix the problem Jaguar puts out a communication on how to disallow a warranty claim.
As much as I have loved these cars over the years I still wonder how they get away with some of the "stuff' they do. Cases in point, XJ notorious air shock F---up and this aluminium trim business. Everybody in the supply chain is aware of the issues but the head office crafts policies and procedures to avoid doing anything about it.
BTW -the trim staining on my car has returned after the first wash. The metal polish did not fix it.
Old 12-29-2013 | 05:09 PM
clayballs's Avatar
I feel like a voice in the wilderness. Nobody hears me.
I'm willing to bet a small amount this stuff is stainless. Whatever it is on your cars: on my car it is stainless steel, not aluminum and not plastic.
See post #4 by himself.
il lay a bet on that ,mines come off this morn due to ice getting underneath the trim ,its plastic
  #30
Old 07-14-2016 | 06:37 PM
Damo33's Avatar
Default Material used on side brightwork
Just to be crystal clear, Jaguar x250 does not use stainless. It uses a pressure formed aluminium material covered with a protective layer. I have walked around the suppliers factory when I worked for Aston, who do use SS & one piece for the entire length from A-post to E post & back to B post. I don't know if it can be polished out but if it can, it would need re lacquering. Crap durability. My 2008 model looks awful.
  #31
Old 11-15-2019 | 08:18 PM
EliteZags's Avatar
any new solutions for this? so even if you do manage to get it back to clean/shiny it will eventually dull out again unless recoated with some lacquer/coating?
anyone ever tried buffing with Mother's Speed Clay (synthetic soft claypad) and some type of polish
  #32
Old 11-16-2019 | 08:10 AM
Did you read any of the above messages in this thread? That would answer your question since you're just suggesting to polish anodized aluminum. If you want lots of answers to your question about polishing anodized aluminum, here you go:
https://www.google.com/search?q=how+...hrome&ie=UTF-8
In short, don't do it. Just replace the parts, or have them painted gloss black.
Fraser Mitchell
05-07-2017 07:21 PM
Frank mellin 1
02-02-2017 04:21 AM
Rjscharer
09-24-2016 06:03 PM
Russell11
03-25-2013 08:47 AM
Quick Reply: 2009 XF premature tarnish of chrome door trim
