2009 XF Stuck in Park
I tried doing a Google search for help on this, and this forum continued to come up as a good resource, so I'm hoping someone here is able to help.
We have a 2009 XF, it is an early build we actually got it in 2008. And this morning we couldn't get it out of Park. The knob rotated up, and was locked. We shut the car off and turned it back on a few times and nothing. Thought it was the smart key for some reason, and put that in it's little "home." Nothing. Tried to activate the parking brake and then we got an error that there was a "parking brake fault."
Does anyone have suggestions on how to at least get it into gear so that we can move it. It is currently parking in my car, and at a minimum I'd like to try to move it so we've got something to drive.
Same thing happened to many XF's back in the day. I personally got stuck in a Wendy's drive through about 5 yrs ago and had to have it towed to the dealer. Extremely embarrassing during the lunch hour!
There was some type of recall I believe and Jaguar updated my car with a fix.
The tow driver told me that I was the fifth car that week with the same issue. He told me that you need to pry open the Silver piece of rectangular plastic that is located towards the rear end of the center console. It's just behind the cup holders where you open the center glove box. It pops off and there's some cable underneath that you pull up and you can then put the car in neutral. That's what he did to get the car out of park to get it on the tow truck.
Received 3,239 Likes
OzXFR gave you the right information to get to move the vehicle. I know since this happened to me, only mine locked in D. Not so bad except that I was in a driveway facing the garage door, and I was fifty miles from home. Fortunately my 2009 was still under warranty.
Be sure to block the wheels when you do pull up on the release lever as the car will be free to roll. This is how you'll need to be set up to get it on a car carrier and to the repair shop unless you plan to replace the shifter control module yourself, as that's whats gone bad on you. Apparently a fairly common problem that year.
You'll want to use the front and rear tow hooks to hold the car steady on the car carrier. Once on the car carrier, be sure to push the locking lever back into the down/locked position to re-engage the transmission park position, once the car is secured.
All this is detailed in the owners manual in the towing section, I believe.
Good luck.
Good luck.
The repair is simple and there is no issue with the transmission, only the selector is involved. The original circuit boards were defective and a new board cures the issue completely. If you were the original owner Jaguar Canada was supposed to issue you a letter asking you to bring your car in for this repair.
Good luck.
Good luck.
But a little Googling found this informative page, with pics:
How To Tow A Jaguar Equipped With An Electronic Shift Lever
There was a known defect in the circuit board controlling the shifter. These were all supposed to be replaced free of charge under a general TSB program.
Nothing in the Owner's Manual, I checked 3 different PDF versions and my paper version.
Well just an update. I'm currently sitting in a hotel, as yesterday morning the shifter gave up the ghost. The worst part is that I was in the process of driving from Maine to Wisconsin and I'm stuck in Ohio. The dealer is charging around $1200 for the repair. They checked the VIN against any programmes and said that it didn't qualify for any repairs.
Does anyone have any suggestions of any kind that I can convince Jaguar to pick up the repair tab? (Or in this case reimburse me for the repairs.)
How frustrating for you. Unfortunately if yours wasn't one of the early defective circuit boards in the 2009 model year, then I doubt they will do anything for you as it sounds like an unrelated issue. Let us know how it gets resolved - and curious to know what the specific issue is
Happened to see on eBay today in 'my feeds' a gear shift module for the XF. Says its a 2012 module - not sure if they are the same (it looks a little different from my 2010) - but that may just be aesthetics vs function. Anyway it's 199 dollars which is I'm sure much less than dealer.
Search for this
Jaguar XF 2012 Gear Selector Module OEM CX23-7E453-BE Scratched, see pictures. New.
Search for this
The paperwork makes mention of a ground short in the shift control module, and i have the one out of it. I didn't have time to look or wait for eBay. I was stuck on a trip with a hard deadline and really needed to get it fixed asap. Which, unfortunately, meant that a dealer was the fastest option. It cost about $1100 for the repair. (though, im also currently now stuck on airplane waiting for storms to pass, but that's another story.)
I have a 2009 jaguar xf supercharged that is stuck in park. The gear selector is brand new and the transmission fault light is on the dash board. The codes I got were p2725 -a permanent, p2727-13 intermittent, p1707-72 historic. I also got these from the ecu U0101-00 historic, U0405-8f intermittent, U0402-08 historic. The gear selector won't move from park at all. I would like some assistance as to where to go from here now wether I need a new transmission or valve body or something of the sort.
Why is there a new gear selector knob? Was that an attempt at fixing the issue?
As a starter, how strong and well charged is the battery? What voltage are you getting across it with the engine off? That's a good place to start
Then - what other symptoms. Does the car start and run ok? Is the alternator providing power (or what's voltage on the electrical system when car is running)?
