2009 XF supercharged rear wheel bearing DIY
I couldn't find a DIY on a rear wheel bearing so I thought I'd throw some quick pics up.....not very detailed as this job is pretty much like any press out bearing you've ever done.
So its a pretty typical press in/out. Use a front wheel drive hub puller and a slide hammer to get the stub off. I used a hub tamer you can borrow from most parts stores to do the bearing so guys that don't have access to a press can see one of those work. Just remove the caliper and rotor. I only loosened the caliper mounting bracket and the rotor slid by.
Getting the snap ring out stinks. Keep at it, it will come. Now get the axle out. I had to take the hub free from the lower control arm to get it out.
Here's the hub off so you can see the back where you situate the tool to pull the bearing out. You don't need to remove it using the hub tamer. With it totally off it would be just as easy to put it in the press, if you have one.
Hub tamer in place. Tighten the nut to pull the old bearing out, then the tool gets swapped around to pull the new bearing in from the other side. Re-assemble opposite of disassembly.
Random mid-job pic.
Random mid-job pic.
Good write-up. Do you happen to have a torque spec for the axle retaining nut?
BTW, what were the symptoms of the bearing going bad? I recently noticed a faint "rotational sounding" noise, on our XF, that goes away as soon as I touch the brake pedal, then returns when I get off the brake. Hoping it's nothing serious.
If the noise changes with speed and stops when you "hold the wheel straight" with brakes, then a wheel bearing is a likely contender.
wesmc (06-22-2019)
However, if it's indeed a wheel bearing, better I take care of it now, while the newer Jag is on the road for the summer, and I have the time to mess with this one, to get it ready for daily use, in a few months.
Thanks for the "heads up"...I'll check that out. I was also thinking that just maybe, it could be just a little "crud" that built up on the outer edge of the rotor.
Just a follow up....
I took off the rear wheels, and looked things over, but found nothing out of the ordinary. I did, however, notice that the brake pads were down to about 30% thickness, as we all know that XFs wear our brake pads at a fairly prodigious rate, compared to the fronts. The pads had about 14-15,000 miles on them, so I decided to replace them now, rather than try to squeeze another 4-5000 out of them and have issues in the dead of winter.
I ordered another set of pads (Powerstop ceramics), and pulled the rotors off. As expected, the rotors had a fair amount of "crud" around the inner and outer perimeter, where the pads don't touch. I used my "California brake lathe" (a disc sander) to clean off the crud, scuffed the contact area with some sandpaper, and re-assembled everything. I then went out for both a test ride, as well as a "brake bed-in session". Long story short, it appears that my noise is gone....so far!
wesmc (06-30-2019)
rdcsat
11-16-2007 06:20 PM
