2010 Jaguar XF 4.2L throwing code p0184
2010 Jaguar XF 4.2L throwing code p0183
Hi guys I’m new here” my name is Kerry..
hopefully someone can help me. Recently my check engine light came on. For code p0183 fuel pressure sensor. My question is should I just replace the sensor? Car still runs flawlessly. Only problem is, car is burning gas faster than usual
Fuel temp sensor trouble
Good morning guys I really need ya’ll help 🙏🏾 😩
my 2010 Jaguar XF 4.2L v8 runs beautifully. but recently check engine light came on for code p0183
fue temp sensor.
I need to know if this part is under the the hood or in the fuel tank?
car still runs good, but sucking up gas very fast!
please help
fue temp sensor.
please help
You need the workshop manual. If you google a bit it can be found free like this one
https://www.dropbox.com/s/itzjq6rti2...anual.pdf?dl=0
Search that and
Fuel Pressure Regulator on page 1516
Fuel Temperature Sensor on page 1974
Search that and
I've merged your THREE separate threads on this same question here and deleted a FOURTH from the US Lower Atlantic Region forum. Do NOT multiple post the same question.
I replied to your Intro advising this code can indicate either a faulty sensor or a harness fault. JagV8 has given you the same advice in post #2 and litteredwithfaults has given you a link to download the Workshop Manual in post #5.
The Workshop Manual gives detailed information on the Fuel Temperature Sensor (item 5):
JagV8 (10-08-2021)
Andrew Dodds
11-05-2018 01:22 PM
darrellleece
08-25-2017 10:56 PM
