2010 XF not starting. Battery issue?
#41
I Know what your problem is but I'm not going to tell you. Techs within the Jag community keep info to themselves, so unless your battery is bad, then there is a drain. But chances are your battery is straight up bad. Jaguar doesn't make their own batteries. There is really only a few battery manufactures in the world. They just slap different stickers on the batteries. How often do you drive the car anyway? Does it sit? Was it sitting for more then a few days before you started it?
#42
But isn't that what we are all about? Helping each other have the best experience with this wonderful car. I would share any information that would help a fellow Jaguar owner have the best information he/she can have to make life with this car the best experience the they can have.
The following 2 users liked this post by hlgeorge:
axr6 (05-14-2013),
Long Islander (03-04-2014)
#44
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
The state of the original battery is not affected by jumping. Any jumper cables are connected in parallel to the car battery and no current passes through the dead battery. Any charging happening would feed both the dead battery and the jumper battery simultaneously. The jumper battery cannot charge the car battery.
If the engine won't turn over with a jump from a known good battery then your problem is with the starter or its wiring. The alternator is never relevant to a fail to start except if it is the cause of the dead battery. A failed alternator will not prevent the engine from starting and running.
al_roethlisberger
09-11-2015 10:04 PM
