2010 XF S/C rear camber?
Hello gentlemen, I had a question regarding about adjusting rear camber on the X250 model. I recently had new wheels put on my car and an alignment done. After a day or two I noticed my right rear wheel rubs the fender, I have had my fenders rolled and it seems to work very well for the left rear but not the right rear. Then I went behind my car and noticed my camber on the left is right around -1.0 degrees which is correct but my right rear is almost straight up and down. Now my question is, is this because a worn suspension component on one of the sides? Because I tried to do my research and I found out the rear camber is not adjustable on these cars but I also found someone else of the forums had the same problem and the alignment shop adjusted the cradle to get the same rear camber on both sides. Before I took it to the alignment shop I put my car on a lift and inspected all the suspension bushings and components for any wear so I am at a lost here. I appreciate all your advice and help.
Much Thanks!
Much Thanks!
Lagonia
10-24-2018 01:42 PM
